dlphnfn
- April 23, 2004
- Cental Iowa
- 17 Sport
Hi All.
I have been searching, but can't come up with a conclusion. My 2000 EB 4 door's drivers side window is stuck about 4 inches down. It won't go up or down. If I click on the UP, nothing happens. If I click on down, you can hear the relay under the dash click. I took the relay out and it stops clicking when you click on DOWN. The odd part is if you click DOWN, then UP, it "resets" the DOWN and it clicks again. If you click DOWN twice in a row, it doesn't click the second time. Does that make sense?
I just tried to inspect the wiring in the boot between the door and the jam. Everything looks OK from what I can see. I suspect a problem in the relay if it is making noise though, not wiring.
Anyone have any thoughts? Or other threads that I may have missed? Thanks as always.
Erick --
BTW - This has been an intermittent problem for quite a few months. It just now officially "died" on me. Seeing as this is the wifes daily driver, it needs to be fixed yesterday!!
Erick --
