I am paying a premium for top-notch work and that is why I went to him. But he knew from the start that I didn't want to spend a lot on this and when we saw that we had to replace more parts than we both originally expected and planned, then he was nice enough to cap his hours. So basically he gets the job done and he stopped billing at a point because I told him I just couldn't afford anymore past that and he wants me to walk away happy at the end. After today, he's already at 22 or 23 hours labour put in over the past 4 days and once you factor in the total cost for all the parts and the amount he had to spend on extra tools and doing a fabrication for the harmonic balancer, plus stuff like bleeding out the air, oil change, ATF change, ATF gasket and pan (labour that he's not even charging me for at this point) because he has capped his hours about a day ago, he's now been working for below his hourly rate and by quite a bit. So I can understand his point here. When he took this on, he did not see it turning into a mid 23+ hour job because he would have turned it down. And now it's not even done because the coolant is leaking (likely from somewhere else but he will check in the morning as he needs to clear his head). For him, it's all about having return customers.
He is not happy about my truck being in his shop for 4 full days now and he's had to turn down several jobs so basically he is losing money. He said he can't afford to keep losing money by turning down other jobs. I think if it is the timing cover, he should fix it (even though he has to tear it down again) and yes that will be another full day when you factor in diagnosing. He said that when he had the timing cover off and out, he hit it with degreaser 4 times and even used a brush to really clean the metal inside and out. So all the crud that he cleaned off everywhere that was holding up the engine before is now gone. This is a risk you take when fixing leaks on an old car.
We know the coolant leak is coming from the timing cover area, we just don't know if it's through the cover or where yet but he has a very strong feeling there is a crack in the timing cover. Man if this is the case then I give up as I'm just not willing to put another penny into this and buying a new timing cover is going to cost a fortune. He also said that he didn't look over the cover like with a fine tooth comb and he did check it but just assumed it was still in good shape. It has been a huge job for him and it's been stressful and I can understand how some can lose focus or just need a mental reset before continuing on.
He will check it in the morning but my worry is that he will say where the leak is coming from but that he can't keep working or tear it apart on his own time (unpaid). I don't know how to respond to something like that without all of a sudden creating hostility and a bad working relationship between us or offending the guy without intent. All I know is, I can't afford to just lose this money. I cannot put another penny into it. If I put it into it and I don't walk out with a 100% fixed truck then not only am I screwed but I will be super pissed.
I mean I feel bad for all of this and I sure in hell did not expect this to turn into a 4 day job. But it's a really tough situation to be in.
