98FordLove
- January 27, 2021
- Calgary
- 96 Explorer XLT 4.0L OHV
Ask him WHY would coolant be leaking from the harmonic balancer area (it bolts onto the end of the crankshaft at bottom of engine where there is NO coolant paths! )...is he claiming there's a crack in your block??
The end of your crankshaft --where H.B. bolts onto is the 3" shiny cylindrical stub shown at bottom of front of engine at 3:44 mark of video... it has a timing gear and timing chain around it....there are NO "intended" coolant ports / jackets there....that hole in the above picture of timing cover (large single hole at bottom of cover) is where it pokes out for H.B. to go onto.... I'm guessing that seal is damaged / bad and OIL IS GUSHING OUT THERE.....NOT coolant.... maybe you misunderstood him --since the initial leak / issue was coolant.....
I did ask him this last night. He said that the harmonic balancer and assembly could be warped as it is aluminum (which is soft) and over time it could have warped. But he saw where the coolant was coming out of and it was coming from a gap, so that is why he is trying something different today when he goes to re-install it, to get rid of the gap. He is confident that it will work to close the gap but he says that if coolant still seeps through, then it's out of his hands and nothing he can do other than accept it's an old truck and the metal could be warped. As for the truck running rough now, he said that we did too much to the truck and too soon and basically shocked it. Like he said, it's basically like giving a 100 year old person a heart transplant, it's risky.
