Drool City | Ford Explorer Forums
Drool City
410Fortune
Truck Season!!
Staff member
Moderator
NORTH IDAHO, 7B
B2 "Slightly" Modified
Callsign
FOURTEN
Bah...rather have this :D
It's based off the Ford 4.6 Block
Type: V8 cast aluminium, 4 valves per cylinder, double overhead camshafts. Cam cover of carbonfibre.
Displacement: 4.700 cm3.
Compression: 8.6:1
Weight: 215 kg
Lubrication system: Dry sump with unique oil spray piston cooling. Oil cooler.
Oil: SAE 10W60 fully synthetic racing.
Oil tank capacity: 12 litres (2.64 gallons)
Induction system: Sequential, multipoint fuel injection. Dual Rotrex centrifugal compressors with 1.4 max boost pressure. Intercooler.
Fuel: 98 RON unleaded.
Ignition system: Direct coil on plug. Transistorised.
Power output: 806 bhp at 6.900 rpm.
Maximum torque: 920 Nm (678 ftlb) at 5.700 rpm.
Maximum rpm: 7.600 rpm.
for $4K?
Add at least one more decimal place....dunno the actual price, but I'll bet it's damn expensive....:eek:
Compression: 8.6:1
Weight: 215 kg
Nice motor but dunno about that dry sump oiling on the street:dunno: could be a PITA
10w60 synthetic? I wonder where you order that from
-Drew
I can borrow you $4000 :thumbsup:
but you have to pay 200% interest up front :thumbsup: :D
and 98 octane sure would be fun to run all the time too plus you gotta fit the 4.6L in the truck!
