I've posted and posted and got nothing. But here goes again. 1997 Explorer E.B. V6 4WD.
"New here, so here goes. Today before work, I bought a 1997, Explorer, E.B., V6, 4WD, with 172K on her for $600. The only issue is what I believe to be the transfer case. When I start it up, the 4low or the 4WD light is on other than that, everything is fine, as long as it's in park. I can put it into drive and drive it in whatever mystery state it's in. I believe it's stuck in 4low. Then if I go to put it into ANY other position, Park, Reverse, Neutral, Drive, Two, or One, I get this grinding whine sound and it stays in whatever mystery gear it's in, continuing to move forward under idle power. I have to shut it off and then shift it back into park or neutral depending on the situation. First Question: Am I correct in assuming it's the Transfer Case? Second Question: Could the issue with the transfer case have damaged other parts of the rig, such as the transmission? Third Question: What would be cheaper on the wallet, scrapyard TC or a rebuild kit? Oh, and one last thing, I also have another 1997 Explorer E.B, that's a V8, AWD, with a tow package, I was going to use it to tow the new Explorer home but U-Haul said “No Explorers”, Why? Thank you. "
"Here is the situation: Bought a 1997 Explorer E.B. V6 4x4. I start it up, I shift into drive, the 4 Low light is on. I go to put it into park and I get a loud grinding/whine, I go to put it into neutral, I get a loud grinding/whine. I go to put it into any gear and I get a loud grinding/whine, and the vehicle continues to move forward under idle power in all gears. What do I need to tear apart? "
