86BroncoII
- February 25, 2009
- Roy Washington
- 1986 Bronco II
So, in the past I had a Bronco II that I modded a lot with Waggy axles and leaf springs, etc. I sold it a while back and now am looking for something again. However, this time I do not want the full rock crawler off roader. I am looking for more of a mild Overlander/Avdenture rig for mild trails and camping.
I plan to do Forest Service roads, Fire roads and the Back Country Discovery Routes. I have done them on a Motorcycle and have seen plenty of jeeps and other trucks on them .
I want a V8 and I want a 96-01, prefer 97-01. I want the GT40 heads if I can, but any 96-01 will work. I want the 96-01 due to the fact that it is the only small SUV that I can lay down in the back of, all the others are too short in the back. So, it has to be a 4 door.
So, the questions I have are these:
1. How well will the AWD work for mild off-roading? I know I can install the 4406, but that will be a while.
2. What years are best?
3. What should I loo out for?
4. Price seems to be $1500-$4000 for nice ones, what would you pay?
More info. I will have a winch, I have a High Lift, I have experience. I want the V8 because of the power and I like the 5.0l engine. The trans is also much better int he V8s. Gas mileage is of little concern, I work from home and will only use this for fun. I also just moved to a large piece of land and I have a steep driveway. When it snows, my wifes car gets stuck at the bottom. So, it will get used when it snows, but that is not that often here. (Yakima Wa.)
Any other advice would be good. I can't afford to buy the wrong one, need to get it right the first time.
