JohnFornaro
- November 10, 2002
- C'ville, VA
- 93 Explorer
I have a 93 Explorer, w/ Goodyear 235-75-15 tires. All Terrain somethings. (I should have this info better at hand, but I don't think that the brand and type of tires is the problem.) These tires should have at least a full season (Summer 2003 and the following winter) left on them. Over the last 18,000 miles, there has been a front end vibration, slightly noticeable at 35 mph +/-, and rather more pronounced at 65 mph. At 55, the ride is pretty smooth, at 75, the ride is smoother than at 65.
I just had (5-16-03) the tires dynamically rebalanced on a Hunter machine which also measures out of round. My mechanic tells me that the tires are so out of round that they're causing this front end vibration. However, I he's balanced them before, and the vibration came back. The Right front tire has very obvious signs of cupping. It seems more to me that there is some other problem here with the front end. Any ideas?
I replaced the front and rear sway bar bushings last year, the front bearings last year, and the shox two years ago. Mechanic poo-poohed the brand of shox: Advance Auto Top of the line gas ones - $35 each, with a lifetime warranty. He proposes the Federated equivalent, a $35 shock that he'll give me for $75. Mechanic reports that ball joints are ok.
The manual shows an unusual frame to engine shock mounted at the front left wheel, but this option (or fix) is not on my Explorer. Actually, I've looked at several older Explorers in parking lots to see if I could see this vibration control device, but haven't seen it yet. (Hey Ma, why is that man crawling around on the pavement around our car?)
I know that this all sounds like a lot of front end issues, but I put it here because mechanic is adamant about the problem residing in the tires.
Any ideas or comments would be welcome. Thanks
