domeshot14
- April 23, 2009
- Perrysburg, OH
- 99 XLT
Hey guys, before I explain my problem with the speedo here is a little rundown of recent happenings with the trucks electrical system. First off it is a 99 4x4 SOHC. The power locks don't lock unless locked from the switch by the rear lifgate, but they will unlock from any switch. Drivers door will unlock fine but has to be locked manually (?). ABS light came on 2 weeks after new hubs and sensors. Double checked them again and still nothing so I bought a rear ABS sensor from Autozone but haven't had an opportunity to crawl under the truck and replace it this winter. Just last week I installed a 12" Kicker subwoofer and 1250w Power Acoustic amp along with a new stereo. Everything was fine for a couple days then that's when the speedo/odometer started to function intermittently. Now it hardly works at all and when it does it's not very long. The CEL came on the other day but the next day I started it up and the CEL was gone without me doing a thing.
So my question is, does the rear speed sensor affect the speedo or is there another speed sensor on the truck that I should look for? Also, what would have thrown the CEL and then caused it to turn off by itself? I'm not sure if this has to do with the subwoofer/amp being installed or if it's just coincidental. For what it's worth I used 4 gauge wire for the amp power and ground, and a 100A inline fuse. If anyone has any suggestions please run them by me even if you're not 100% sure I would appreciate any help I can get.
