Enclosure Dimensions? | Ford Explorer Forums
karter74
Overland Park, KS
92 Navajo
Hey guys, I plan on builing my first box soon and wanted to know what kind of dimensions you guys used for a dual 12" box. I want to make the slotted ones I see, or possibly sealed. Anyway could someone give me like some dimensions they used to build theirs, and if possible, a box that conforms to my wheelwells (92 navajo,basically an explorer sport) Pictures would be plus! Thanks in advance!
It all depends on a few things like...space, how much do you wanna take up?? How much space does the manufacture reccommend, better yet post a sites information on the sub, what kind etc. That should get you some help. PS, if its your 1st time building a box (Ive built 3) your better off going with sealed, if you wanna make things eaiser, unless you can get some detailed information from others here or some friends around work, school, whatever..
Ok, I have the Bazooka Concert Series Subs (Dead Link Removed) I really don't care about space, just want it to conform to the wheel wells but try to take up as little space as possible.
Its a lot harder to make the box conform to the wheel well, better doing to angle, im saying picture to piecies of wood that are put together at a angle that would go up and over the wheel well. Check out my page below and go to page 3 to know what the heck im talking about
I thought about having my box conform to the wheel wells, but went against it. I think it would be pretty easy, having made my false floor conform to the curves of the trunk space. For a box, I would just make the box whatever size is required in terms of length, width, and depth, but then extend the front and top pieces to fit to the wheel well... Basically, a sqaure box with two panels that extend out past the main sides of the box, purely for cosmetic purposes. That way, you don't alter the volume of the box, and you don't have to mess with cutting curves into a bunch of panels and having to deal with getting them all to line up right and seal well together. When I had to cut my wood to conform to the curves of the trunk for my false floor, I just made paper mache molds of the curves... Soaked some strips of newspaper in a flour/water mix, slapped them onto the panels, and let them dry for a while then peeled them off. When it came time to cut out the wood, I just set the paper mache molds on the wood and traced the inner outline. Worked like a charm! A perfect fit.
OKay here's the deal. When you build a box you dont build it to fit the car only, you also need to build it to fit the speaker. There is more to building a box a certain size and dropping a woofer in it.
Your speaker comes with specifications, you need to use these numbers to design the enclosure, also the design and type of enclosure you build should be based on the type of music you listen too most often. I ALWAYS prefer sealed enclosures over vented or band pass, but thats just me. So start there, THEN you can make it fit the car.
Also check with the speaker builder, often they have already done all this research for you and have a specific enclosure design that works optimum with your driver.....
I have been building enclosures for many, many years (i'm getting old), I have probably built near 80 or so boxes, at least 20 of my own, the best one's are always the one's that are matched to the speaker, not to the car......
When it comes time to build it use nothing less then 5/8" thick MDF, assemble the box with liquid nails and wood screws. Space out the screws about 3-4" and pre drill all the holes. Use caulking on the inside corners, and you can line at least 3 sides with speaker insulation (available at radio shack for cheap!!). Interior bracing also may be required for some high power drivers and systems. Also when calculating the interior area of the box, dont forget to subtract the amount of airspace the woofer will displace when installed!! Meaning if they recommend 1.5 cu ft of air space for your woofer, that probably means you need 1.5 cu ft PLUS the speaker's volume.
Thats just my advice, I have seen all sorts of designs, materials, and exotic layouts, some of them work great, most of them are a waste of time and $$$. the more basic the design the better.
I agree... Mine is made to the manufacturer's specs, I just happened to make it fit perfectly between the wheel wells. I knew that that is what I wanted it to do, so I then adjusted height and depth to get the right internal volume... If you just arbitrarily build a box and put the subs in, more than likely it will sound awful.
I built mine just like B94Sport mentioned. It is basically a sealed box with two pieces of wood (panels) attached to the box which fit over the wheel wells. Pics are below:
