eeek ok
Ranger, Explorer, Aerostar 4.0L OHV (pushrod) is basically the same block 1991-2001
There were small internal changes, especially to the heads
The oil pans and pickup is different 95+ because the Explorer had IFS (Gen II)
The Ranger didnt get IFS until 98
I am not sure about the Aerostar oil pan setup
The intakes are aluminum 91-94 and pretty much similar
the plastic intakes 95+ change a few times
the fuel system went from a return style fuel regulator to a non return style system in 98 I believe
the 97+ OHV block has an 8 bolt pattern on the crankshaft (flywheel/flexplate) but the parts are interchangeable
Other then that the OHV 4.0L remained basically the same from 1989 (I believe some 89 rangers had a 4.0L, maybe 90 was the first year) to 2001
The transmissions are a whole different thread, the automatics are computer controlled and the computers change basically as follows:
91-92 simlar (single 02 sensor, MAP sensor, EGR)
93 no egr (CA = cam sensor)
94 egr and cam sensor
95 odd ball computer, EEC_IV computer in a OBD-II truck
96-97 similar (first year OBD-II)
98-2001 similar
the 5 speeds will pretty much interchange, but you can run into problems with slave cylinders, speed sensors, and more
