Nibsey
- July 1, 2008
- Nanuet, NY
- '02 XLT
This is really beginning to drive me crazy. I have an '02 XLT that starts like a champ and appears to idle just fine. When warmed up, if I go up a hill (accellerate) or start from a stoplight, the engine will make a "pop/skipping" feeling at about 3500 rpm. This goes away once I get up to cruising speed. It only happens when I'm accellerating - and usually around that 3500 rpm mark. I've also noticed that the car is pretty sluggish when trying to pass cars on the freeway, etc.
I've changed the plugs, wires, coil, replaced the MAF, ran several cans of injector cleaner and still have this little skip. If in park, I can give it tons of gas and can't replicate the skipping. It only appears to occur when its in drive. Thoughts?
I don't know if this is at all related, but when I replaced the MAF and had the battery disconnected, the car ran great immediately afterward. Then after about 30 mins of driving, the skipping problem returned.
I was leaning toward replacing the TPS but wasn't sure if that's only an issue for high/low idle issues. Could a bad TPS cause a slight misfire feel during accelleration? No error codes are being registered.
Thanks in advance for any advice!
