Exhaust leak | Ford Explorer - Ford Ranger Forums - Serious Explorations
Exhaust leak
Minivek
Quebec, Canada
'03 Limited Ex silver
Merry christmas everyone, hope everyone's having a good time and relaxing!!
I have a couple of exhaust leaks on my 94 2dr, the donut gasket between the cat and the muffler is 3/4 gone, I'Ve got at least one maybe two in the engine compartement (seem to really come from the driver's side) I was wondering if theses can go unnatended for a while, or do exhaust leaks have more repercussions than just that ticking noise ?? basically could it affect back pressure and what not or is it just sound pollution and that's it..
Thanks a lot!!!<
marragtop
balt, md
91, 92, 95, and 2000 xlts
Exhaust leaks can put carbon monoxide inside the truck. The leaks are only going to get worse, so I suggest you get it taken care of.
Minivek
Quebec, Canada
Other than pollutants and CO in the vehicle, do exhaust leaks cause any problemes performancewise?
Thanks!
Minivek
Quebec, Canada
Minivek
Quebec, Canada
Charlie's_93EB
Cat 3 Hurricane Rated
Venice florida
1993 Eddie Bauer
Thanks!
I would think that it helps the flow, just let it go and enjoy the sound.
adamhc
Tampa Fl
'93 Limited
Pull the exhaust out and run flexpipe to the back. about 40 dollars complete. I have even considered pulling the cat and pipe it straight to the headers. Not sure yet though.
adamhc
Tampa Fl
'93 Limited
keep in mind though that if you do pull the exhaust from cat back. You WILL set of car alarms. that should give you an Idea of the noise level with out muffler. I myself like the exhaust note that the truck has now. Not sure at any performance gains or losses with the flex pipe as it seems the same as before. Just a lot louder.
MoabB2
South Jordan, Utah
89 Bronco II (97 Mercury)
Thanks!
Yes, exhaust leaks can cause problems performance wise. It depends on where they are and if they are affecting the O2 sensor readings.
little x
SW VA
'91 XL
I had a bad leak just after my headers for a few weeks and my truck lost sooo much power I could barely drive it. Starting in first up a hill, forget about it. I'd fix the leaks.
Minivek
Quebec, Canada
Cool, thanx a lo guys, hadn't seen all the replies here, and you've been real helpfull. In fact, I've got a leak tight at the engine block, o where the Y pipe connects, and I've come to notice that it has no low end torque whatsoever... Gonne check it out this weekend.
anyone have gasket part numbers for the exhaust?
THanx a lot :salute:
uh60james
Fayetteville, NC
'93 Sport (Dora), '06 XLT
I got my exhaust leak fixed at a local exhaust shop. It was the flange holding the pipe from the cat to the pipe to the muffler. He didnt even use a new flange, just got a small piece of pipe and welded it. Cost me $10. If you have a small local garage, they can probably hook you up for cheap.
