Mexplorer
- August 9, 2005
- Nayarit, Mexico
- 96 XLT
Well, some years ago i did not posting something here....since my explorer has been a very reliable vehicle for the last years, i rarely have a problem, other than routine maintenance.
My truck is a 4 Door Explorer 96, V6 4 liter, Automatic transmission, 4WD.
Dad had the truck over a year and barely used it, like one time every month. I told him that i wanted to use the truck some time, make a proper tune-up and another small fixes. I drove the truck a hundred miles and worked ok, a little sluggish (i think i need spark plug wires and newer platinum plugs-changed them the last time in 2006)but nothing bad actually. Something i noticed that the speedometer needle was a bit shaky when traveling more than 50 MPH, but i can live with that.
Yesterday i got a phone call of dad telling to me that one time he got stuck in a small beach near where he lives, even when he put a brand new set of tires (Euzkadi all terrain 31x10.5R15) and of course, had 4WD. He was in doubt that the 4WD system was not working at that time, even when he did the right procedure and got the light in the dash, it appeared that the front axle wasn´t putting any power.
Well, i decided to test it. Went to a small hilly area near from house, put the selector in 4WD AUTO, light on, and floored it......and got a bunch of wheel spinning from the rear, and not the normal "front pull" from the front axle kicking it. Put the selector in 4WD LOW, both light indicators were on, got the normal noise from the transfer case shifting, floored it.....and GOT even more wheel spin ! i had 2WD low ! the front axle did not put any power. Tried like 4 or 5 times more, with the same results.
I need to add, that if i try to shift to 4WD AUTO from 2WD "on the fly" with the vehicle running, the light indicators simply doesnt work, and after 10 seconds they start to blink, both 4WD and 4WD low. I if shift from a complete stop in D to 4WD Auto from 2wd, the light works as normal, but, of course, no 4WD action.
I hope i have been clear. My english is not the best. Any help would be very appreciated. Im right now starting to read the stickies in the tranny forum.
Greetings from Mexico.
