alex101
- July 5, 2012
- Location
- Surrey
- Surrey
- Ford Explorer XLT 2014
Hi Guys,
I have Ford Explorer 2014 XLT, 220K km, regularly maintained.
Last year I had check engine light and dealer replaced one of the sensors.
Spart plugs and intake manifold gasket were replaced as well.
Since then I noticed that it started to consume more gas.
It used to be 10L / 100km (23.5 mpg) and now it is 13L / 100 km ( 18 mpg).
This is quite a bit of increase in $$$ - actually it is almost $4500 / year increase per 70K km we plan to drive this year.
Is this normal or should I try to get a better mileage from my car?
What can be done to reduce fuel consumption?
There are few suggestions I've heard:
1. Check compression in each cylinder to make sure it is correct
2. Check oil and air filters and replace them (done)
3. Check transmission fluid and replace it if necessary
4. Replace two air sensors
What do you think?
What should I do in this situation ?
Anything else can be done to reduce gas consumption ?
What's your typical consumption in city + highway ?
What do you think?
