Adamsvilleusa
- January 29, 2008
- 1998 Ford Explorer
Hey Everyone,
I have a 98 Ford Explorer Eddie Bauer V8 and I'm having difficulties trying to reverse a Catalyst efficiency code.
The code reads: P0430 - Catalyst Efficiency Below Threshold Bank 2
So here's the scenario - I have replaced a down stream O2 sensor (bank 2-Driver's side as far as I know) and the code still comes up. Before I go further... I've heard to disconnect the battery after replacing the O2 sensor? Is this true and also is there anything else I should do in regard to my new O2 sensor installation?
The O2 sensor is now installed and the CEL is still on. Aside from changing the cat, is there anything else I should check first or does it look like a new cat is in order? Should I have a diagnostic test done? Any suggestions are greatly appreciated.
Thank you very much, this forum has been great to me so far!
