Explorer HID Projector mod | Ford Explorer Forums
JGB98EB
Monroe, CT
1998 Eddie Bauer
I finally got tired of my 9007 HID kit in my stock halogen headlamp housings. The beam pattern was awful and people would always flash me because they thought I had my high beams on. I started out with 6000k bulbs which were way too blue. I finally took them out after almost hitting a fallen tree branch in the middle of the road (it was not easily visible due to the hue of the headlamps). I then switched to 4300k Philips bulbs. They illuminated the road better due to their hue and brightness. The problem was that they looked boring from the outside and still had that lousy beam pattern which would cause people to flash their high beams at me. About a month ago, I saw some BMW X5 (Hella) projectors on ebay selling for $130/pair. These are the projectors I bought:
http://img79.exs.cx/img79/3873/Projectors.jpg
I had to buy them since they were such a steal (they are about $200/each brand new). I then saw a pair of OEM BMW Osram bulbs (4100k) for $50 on ebay (they go for about $120/each at the dealer). Here is a picture of the Osram HIDs:
http://img79.exs.cx/img79/148/OsramHids.jpg
Unfortunately, I couldn't keep the Phillips 4300k bulbs since the bases were modified to fit in a 9007 housing. Of course I had to order some other items to start the project:
*From Home Depot: sheet of clear Lexan/Polycarbonate (approx 1/8" thick) to be used as a mounting plate between the OEM housing and the projector housing, Loctite Plastic Epoxy, GE Plastic & Polycarbonate Silicon Sealant, and silver spray paint
*2" Sanding Disc Holder, 80, 100, 150, 320, 600, 1000, and 1500 sanding discs (http://www.jacquescoulombe.com/sanding discs.htm) to smooth out the OEM headlamp lenses
*3M Perfect-It II Rubbing Compound (http://www.premiumautocare.com/3mperitcom.html) to use after sanding and smoothing out the OEM headlamp lenses
*A second pair of OEM headlamp housings so I wouldn't have to take them out of my car and risk screwing up the only pair I had
I started out by putting the headlamps in the oven for 8 minutes @ 375° in order for the epoxy to soften enough to allow the lenses to come off (may take less time depending on the oven). Then, I used a dremel tool to cut off the backs of the headlamps. After cutting the backs off, I used a belt sander to smooth them flat. This was the result:
http://img79.exs.cx/img79/1292/ModifiedHeadlamp.jpg
I sketched the profile of the smoothed back of the headlamp onto the clear lexan sheet. Once the sketch was complete, I used a dremel to cut it out. Then, I sketched a hole to match the profile of the projector onto the cut out piece of lexan. The projector profile was sketched such that the projector lense bracket would fit snugly through the hole once cut out. After cutting out the hole in the Lexan piece, I drilled holes that were aligned with the mounting pattern of the projector housing. I then used the silver spray paint to paint the back side of the Lexan piece (to match the reflective paint on the inside of the OEM headlamp). Unfortunately, the projectors I bought were too large to fit inside the OEM housings. So, I had to dremel out notches in the top and bottom inside surfaces in order to just squeeze the projectors in. By using nuts and bolts (M3 or #4 would work) to mount the projector housing to the Lexan piece, the Lexan could now be bonded to the smooth back of the OEM headlamp housing by using the Loctite Plastic Epoxy. I then sealed the area where the Lexan met up with the OEM headlamp back with the GE Silicon Sealant. I also used the sealant all around where the projector housing met up with the Lexan to make sure the assembly would be water tight. Then, I modified the OEM headlamp lenses. I started out by sketching 3.5" circles on the insides of the lenses. I used a dremel to sand down the rough texture of the lenses within the 3.5" circle until they were relatively smooth. Then, I mounted the sanding disc holder to a drill press (a regular drill would work too) and sanded the surface within the circle. I started with the 80-grit disc and progressed all the way through to the 1500-grit sanding disc. While sanding, make sure to wet the discs or they will cause melting of the plastic shavings, leaving streaks in the plastic. Once I was done sanding, I coated the smooth surface with the rubbing compound. I used a buffing wheel to remove the compound and polish the surface until it was clear. An orbital would probably be able to accomplish the same result. Once I finished, I put the lenses back on the headlamp housings and was ready to install them in the car. It came out looking like this:
http://img79.exs.cx/img79/7562/CloseUp.jpg
Here is another frontal shot of the car:
http://img79.exs.cx/img79/1816/ExplorerwithProjecto.jpg
The HIDs look just about identical to BMW 325xi HIDs (right):
http://img79.exs.cx/img79/4840/ExplorervsBMW.jpg
The beam pattern came out alright:
http://img79.exs.cx/img79/6407/InfamousGarageDoorSh.jpg
Sorry for the lack of pics. I didn't take pics of the whole process. If you plan to try to make some projectors, send me an email or IM and I'll try to give a more detailed procedure.
That's awesome, nice job!!
Great job man, that is pretty cool.
By the way does it look like his X is staring you down?
very neat and different. props to your work! :)
now that is a unique mod. very cool stuff
I've had them in for four days now and haven't had anyone flash their high beams at me. So far, so good. I used to get flashed just about every night coming home from work with the old setup.
Very nice. I didn't have the balls to fit the projectors in my headlamps, had to get it done :D
Yes, it's very risky--especially when you're using a dremel tool that likes to skip around the surface of the plastic. Notice that I didn't get diamond headlamps and stuck to OEM. I was hoping the diffuse-style lenses would cover up any mistakes I made ;)
it looks great. good work. Does anyone know if they sell kits for a 98 explorer that just bolt right in? I know they make them for older f150's.
They do not. Gotta be a retrofit.
Very beautiful!!!
Very nice job, they look great.
thewishkah said:
those are sick looking,how hard is the wiring and how hard was the mounting? is this what the lights looked like? http://cgi.ebay.com/ebaymotors/ws/eBayISAPI.dll?ViewItem&category=36476&item=7938037019&rd=1 and would these work?
Your headlamps are different, I was told the biggest bi-xenon (lows and highs) to go with would be 70mm, such as Mercedes E320 by Hella. You will wanna go with D2S bulbs (D2R are meant for reflector-style projectors). Bi-xenon means you get highs and lows, xenon is just lows. The bi-xenon have a shield that moves to allow more light to shine. You DON'T want auto-level/auto-adjusting projectors. Every bump you hit will cause the lights to move around.
Wiring's easy. USE A RELAY. Cut off your stock headlight sockets. Run a 30A fused lead from your battery to post 30 on your relay. Run a wire off 87 to your driver-side ballast. Use a 15A fuse. Splice near the relay off that same wire, run another 15A fuse to your passenger-side ballast. Post 85 is ground. If you get highs, the + wire for the shield solenoid of the projector will go to your stock high-beam wire. You need a diode on each solenoid + wire or your high beams won't work properly. Low beam wire of the ballast to the stock low beam wire. You can also buy custom harnesses that'll plug into your stock sockets if you don't wanna make your own.
Here's the diagram I went by when I wired mine up:
www.hidplanet.com is a great place for stuff like this.
ok im intimidated and not so sure i can do this work, maybe the fabing for the mounting but i am no good with wireing and dont want to screw up what I buy, maybe someone that does this stuff and lives with in 100 miles would be willing to help me out here and ill give em some cash lol that would be great lol
You can buy a custom harness from a guy on hidplanet named DohDoh. For adding the projector, it really looks like you heat the headlamp and pull off the lens, get a holesaw and make a hole in the middle of the headlamp, where the projector would fit in, screw on the projector, use some silicone to seal it, and you're good to go. As for the lens, I hear polishing out the fresnels is hard, so you'd be best off just buying some diamond lenses. I'm contimplating whether I should get some and swap the diamond lens with the stock lens, so my projectors shine better, though they already light up whatever's in front of me like daylight ;)
where would i cut the whole? would I just make the hole from the old lights socket bigger ? or do I have to cut something else? and what color are yours? the color goes by heat? correct? is it possible for me to get green or purple for my x? I know some people complain about them but i like how they look lol
Yes, that's all you'd do. You could use a Dremel, but to be dead-on I'd use a hole saw.
ok my father has some drill attachment thats ment for cuttin holes for door knobs (different sizes) would something like that work or should I use something with less power ?
