explorer lift | Ford Explorer Forums - Serious Explorations
explorer lift
00 explorer
I have a Eddie Bauer explorer with the fender flares wanting to do a torsion twist and shackles can I run 31 10.50s on 15x10 rim some people say you have to do some trimming
Also does anybody have a pic of a lifted explorer on a 15x8 rim
I wouldnt run 31x10.50's on a 10 inch wide wheel. The most I would go is 8.5. I run 31x10.50x15's on 7 inch wide wheels and like them just fun. I also did not need to add lift or trim the body on my 94. Gen 1 and Gen 2's are pretty close in fender opening shapes so I wouldnt think you would need to trim any if you do a lift.
i know every one says you shouldnt run 31/10.5/15 on a 15x10 rims but i am and ive had no problems what so ever i just keep my air pressure up. as for the lift you might have to trim the front bumper a bit and the trim at the rocker panel i had to it rubbed at half turned if a hit a bump. but every trucks different.
How much do u have to trim off the front bumper and on the rocker panel
Do u have a pic of your 99 explorer ?
