i read this chart.... | Ford Explorer Forums - Serious Explorations
99sportxplor3
Dover
2000 sport
95-2001
No lift- 31x10.50x15 on 15x8 rim
1-2 inch suspension lift - 32x11.50x15 on 15x8 rim/ may require some extensive fender trimming
4 inch suspension – 33x12.50x15 on 15x8 rim
2 inch body lift – 32x11.50x15 on 15x8 rim
3 inch body lift – 33x12.50x15 on 15x8 rim/ may require fender trimming
2 inch body lift and 1-2 inch suspension lift – 32x11.50x15 – 33x12.50x15 on 15x8 rim/ may require fender trimming
2 inch body lift and 4 inch suspension lift - 33x12.50x15 – 35x12.50x15 on 15x8 rim/ may require fender trimming
3 inch body lift and 1-2 inch suspension lift – 33x12.50x15 on 15x8 rim/ may require fender trimming
3 inch body lift and 4 inch suspension lift – 33x12.50x15 – 35.12.50x15 on 15x8 rim/ may require fender trimming.
...and i was wondering if anyone knew if 33x13.50x15 would fit with an ex with a 3" body life a tt, shackles, and an add a leaf...(there the super swamper LTB's.. for some reason they dont come in 12.50's. any help would be great. (99 ex sport)
even with a 3.25" wheel backset you may still get some rubbing...a little trim and you should be good...someone else will chime in...:D
Since you have a Sport you're gonna need some 4-door leaf springs as well if you want to run an AAL. The only way to really find out if they're gonna fit is to try 'em out. Like tbars said, you'll probably have to trim some. All explorers seem to be different though.
thanks...and does anyone know why the ltb's dont come in 12.50's?? seems kinda dumb to me...And how hard is it to put in 4 door leafs?
Because Interco likes to make odd size tires for some reason. :confused:
They don't make any 32" tires but they make 31x11.5x15.
Is the LTB's you are looking at the radial or biased ply?
biased ply...there not bad as far as price. i just wsh they made a 33 12.50 in it...
If you can install the body lift, you can install the 4-door leaf springs.
