Duranged84
- September 21, 2012
- 03 Explorer 4x4 4.0
Have an 03 Explorer that I'm tearing down for parts for my 03 Mountaineer I just bought. I want to swap the interiors. The Mountaineer has tan (trashed worn) interior, the Expy has very nice gray interior. Both cloth, both power seat, adj pedals, 3rd row, same over head console rear hvac. Etc. The Mounty has heated ext mirrors where the exp does not. The exp has the auto dimming mirror where the Mounty does not. What about air bags? Can I use at least the gray pass bag from the Explorer or will it depend on build dates? I also would like to use the exp steering column as its in better shape and steering wheel itself is 10 times better. How hard would it be to swap ignition switch and will Mounty air bag work in it wiring wise? Probably stupid questions as they are so close but have seen things on other "twin" vehicles have different wiring colors and connectors before. Also the Mounty gauge cluster is really dim, will the Explorer cluster work? Both are non info center vehicles. I also only got one key with the Mounty, already programmed explorer remote to it, but can I swap locks and have 2 keys for it? Is it a module I can swap from the Explorer for the chip to match or is it in the ecm? I plan to gut both trucks in a couple days to start the swap.
Also, the Mounty is awd where the Explorer is 2wd. Will the front hubs/rotors brakes etc interchange? The Mounty is currently 2wd but have not crawled under to see the extent of how they disabled the awd. Seller disclosed that the front diff is bad and was "converted" to 2wd. Will replace whatever all it needs soon but want to get everything I can use off the Explorer at the moment.
Cliff notes -- want to swap entire interiors, optioned identical inside except for auto dimming mirror, would like to add. Air bags work? Front brakes/hub bearings interchange? Possible to make explorer keys work by changing security module or something? And one small not so important question, will the Mounty hubcaps fit the Expy stock 16s? (Expy is currently being stored about 20 miles away or I'd already have checked) Mounty wheels were very neglected and one has a nasty gouge in the bead area but has had new tires put on. I just don't like it plus they look kinda crappy. Will be installing new heater core as well as my good blend motors, etc.
one last quick thing, how hard is it to swap the door glass in these? Mainly how hard to swap without possibly screwing up regulators. Expy has nice dark tint.
