Another problem....my stupidity...
The stock bolts are only 8" long...not 10"....sooooo...the 12" bolts I bought are 2" too long...haha...
I took my stock ones into Home Depot, they only had 8" long, so I told myself I needed 10"...then I went to McFadden Dales, and somehow I thought my stock bolt was 10" and I needed 12" .....soooo another trip to McFadden Dales to swap bolts...stupid stupid stupid...haha
Well I haven't read anywhere someone doing the Coil Seats and the Coils...just an experiment of mine to see how it sits...I have a friend that works at a Tire and Alignment shop...so if its too out of whack with the F150 Coils, then Ill take them back off and put my stock coils back on...I'm hoping for not much lift from the F150 Coils. The F150 coils are a little thicker gauge and about 1 1/2" taller, but there aren't as many actual coils on the 150 spring...so hopefully it will compress down a little closer to my coil height, but with a little more stiffness.
As far as the sway bar...mine is completely uninstalled.
If this setup puts me into needing a new steering arm then I will get the one for a 6" lift.
Here is my process is the alignment is way off:
1: F150 coils, and seats, seats are on the corresponding side from F150 to Exp (driver to driver, pass to pass) both seats are same height
2: Swap seats from Driver to Pass side
3: Leave seats swapped, replace stock springs
4: Swap seats back to corresponding sides with stock springs
so thats my order im going in...hopefully I stop at #1! haha
The F150 coils fit into the stock coil buckets of the Exp, so no need in change of those for now...
Getting the F150 seats on here is just a temporary lift for the tires I bought, once $$ comes around again, the front end is getting a nice long travel build
A friend or mine builds long travel I beam front ends for a small shop out here, and said $500 and I get any size arms I want
...then the next expensive part is the coil overs...
