slaughterrt
- April 11, 2008
- Old Bridge, NJ
- 2011 Explorer XLT
I have a problem. I took my 99 X to get it's yearly inspection and it got rejected for a number of things. The reverse light bulb is out (easy fix). The 4 offroad lights on the roof need to be covered or removed for inspection (another easy fix).....
The only other problem is the dreaded "Exhaust Leak". My mechanic (whom is a trustworthy mechanic and the same one I have gone to since I could drive) told me I have an exhaust leak. He could hear the leak (i never noticed); he could smell the carbon monoxide (i HAVE smelled it); and he could tell that the truck was not getting much back-pressure (the idle is rough sometimes). The problem is that he did not actually do a visual check to see where the leak is. Unfortunately this is where your help comes in.
I need to know where to start looking for the exhaust leak. (I have experience in leak detecting since I have been working as a commercial plumber for several years, however I have never worked on live pipes that get as hot as exhaust pipes). My first idea was to slop some leak detector on the joints, but with the pipes being so hot, the leak detector would just evaporate when it hit the pipe. Visual inspection would probably not be very effective. Nor would I be able to get my nose close enough to the pipes to sniff around for exhaust (that would be a funny sight to see nonetheless).
What are your recommendations for identifying where the exhaust is leaking from? At least, where and how do I start looking?
Thanks guys.
Thanks guys.
