OK guys, just come in from the rain- its done, a tip for all of you pre mot- the handbrake adjustment is under a rubber grommet on the lower rear of the the hub assembly. The star wheel is turned with a small flat blade screw driver and you turn it from bottom to top on the drivers side, the passenger side is top to bottom. This opens the brake shoes out on the adjuster. Turn the star adjuster till the wheel locks solid- then back it off till it just turns. All of this has to be done with the car in neutral and the handbrake off.
Dont forget it will not be free wheeling because of the diff so expect to feel the weight of the diff as you turn the wheel- get used to the level of resistance by turning the wheels by hand a few times before you make any adjustments- then you can tell what differance you are feeling as you adjust.
If you dont know the state of your brake shoes, take one side off b4 you do this...its safe to assume the other side will be the same for wear...I did and know to change mine sooner rather than later.
PS NEVER- blow brake dust to clear it, go and buy a break cleaner spray, this traps the dust in solution so you dont end up with lungs full of this stuff.
Be safe with the jacks guys!
Yes Howard its an ancient test..not applicable to modern cars- but till its revised we will have to put up with it!
