Kjhadfield
- March 21, 2014
- Panama City Beach, FL
- 02 sport trac 4wd
Alright maybe about a couple weeks back I noticed a slight squeal coming from the pulley/belt area but was very low and intermittent. I bought a stethoscope to try and pinpoint location but that's when my truck started idle rough and if given gas would cut out (I posted a thread about this not long ago, which has happened a few times but over 6 months time)-which is why I never looked into it further because id forget about it. Because of that I forgot to look further into the squeal. Last weekend I installed my tires (265/75r16) and coincidently noticed a louder roar (I had removed the silencer awhile back, which already made a roar) but this roar seemed louder and I chalked it up to bigger tires or gearing (4.10 stock).
Today I opened the hood with engine still running and when I looked, my fan had a wobble and not slightly. I turn it off to try and manually spin fan and I can barely spin it and only a little (like an inch or so). So I did some searching and think I narrowed it to either fan clutch or water pump bearing (which means basicly replacing the water pump?). And if it is either of the 2 then it might have done damage to the other because they share the same shaft, I think. And if that was my issue I should replace the water pump pulley and my stress cracked fan (since I'm there)? And obviously flush coolant.
166k and I'm not losing coolant but I have had a flush on the list for sometime and I have never done it since owned (96k) and don't know if it was ever done. The temp gauge I don't think shows hot (but I'm sure it's referred to as 1 of the dummy gauges?).
It doesn't look like too bad a job, just tight. My question is how long can i push driving it and what are the potential disasters than can follow? I have an appt to do an alignment tomorrow (20 mins drive there) and don't know if I should still go. Could ask for them to look at my above problem or diagnosis it- how would you diagnosis this. If I can be ok driving for short amount of time-long enough for me to buy parts online and shipped, I'll do it but if I run the risk of doing more damage I don't know if I should wait.
Thanks for your thoughts
