Just my opinion -- as others have said -- it doesn't sound like this engine is ruined, I think the backfire/intake gasket theory is the most solid. Even if you have a shop do the repair it shouldn't be SUPER expensive (although shops these days have ridiculous labor rates)
Even if the replacement motor is 100k miles, there's no guarantee it will be in perfect condition. You may end up chasing down other issues - i.e. has this 100k mile engine been well cared for? Are you going to replace the gaskets on it, also? That's more $$$. Also keep in mind, that if the replacement motor is not the exact same year/configuration you may have minor but annoying compatibility or fit issues to deal with. Not sure if this applies to this specific motor, but based on my experience in the past with swapping motors there are usually some minor things. For example I am pretty sure the SOHC motors from 4WD vehicles had an extra balance shaft -- not sure how this affects fit/function in a 2WD vehicle.
I am not so knowledgeable in the SOHC's, but I would check vacuum, and suspect IAC valve, and MAP sensor...or whatever the translation is from OHV to SOHC. Maybe get the intake smoked. It's a really nice truck IMO, I would sink a good bit of time and bucks to make that right.
