FIX/RE-CLEAR ALUMINUM RIMS ? | Ford Explorer Forums
toad
Blue Point, Ontario, CANADA
2007 Sport Trac
My rims are starting to look pretty ratty with corrosion and clear coat peeling from past owners putting wheel weights on the outside. has anyone fixed this themselves I see there are places that do this but I would like to try it myself .Help
TANKS EH, TODD
Clear
I personally did that very thing on my '85 Mustang GT, got a spray on stripper and took the clear off, polished up the corrosion, a good product for that is Magic Mix, you can usually find it in any truck stop, truckers that I know love the stuff. Then you can spray clear over it but make sure it is a clear for auto's like Duplicolor that you'd buy in any auto supply place cause its UV protected and won't yellow. Advised a friend to do the same for his Ranger and it made a big improvement.
Todd, a company called Eastwood www.eastwoodco.com sells a wheel refinishing kit. When you go the site, click on the "buffing/metal finishing" icon on the left side, then the link for the wheel refinishing kit. It runs about $80, and should do all 4 wheels. They also sell a clear coat stripper, and a clear coat spray that you can respray the wheel with when you are done. Or you can also do like Kebber did, get a clear coat stripper, and a good metal polish like Meguiar's or MAAS, and use some good 'ol elbow grease. Then just re-clear the wheels when you are done. The first option will give you more of a chromed look, and may work better on serious corrosion.
Thanks for the info. guys ,I think Ill give it a try whenever I can fit it in . Ill let ya know how it goes
