mine is the delta flow and i dont have my tail pipe on right now lol sounds realy good but im just waiting to get my tailpipe made, should i put a tip on it do they make it sound any better or should i just stick with the 2 1/4 the whole way. another thing im not puttin the resinator back on is that gonna effect anything, also what kinda cat should i get.
If you're swapping cats, check out carsound.com (magnaflow)...
Check out RockAuto.com for a tailpipe - they've got dynomax tailpipes that are mandrel bent and not terribly expensive - probably less expensive than having one made...
i have a flowmaster 40 series on my '92 and it is definetely loud and sounds great. i put all new piping goin from new headers down into H-pipe and ran one 40 series for each side,one for the left 4 cylinders and opne for the right 4 cylinders and the pipes go all the way back and its loud and clean sounding. every time i drive up my street at midnight i see lights turn on in houses as i drive past. it is also a gas hog. i get about 1/2 the distance i used to get per tank. i also put a bigger throttle body and bigger injectors with an all new ignition system but its expensive to drive it now though.
