wisekise
- August 19, 2007
- kentucky
- 1998 sport
i started to install my new fog lights today when i ran into the problem of mounting them. i've got some misc. steel pieces from my slider project but they wouldnt work, then i found some beam clamps from work they worked perfect on the back bottom lip of the bumper. btw a beam clamp is basically a c clamp with tapped 1/4" screw holes used to attach hangers for electrical conduit(lowes/home depot) heres a pic
once i got those burnin i decided to start on some bumper brackets for my off road lights. i searched for ideas and found hokies plans but they didnt match the pic of the real thing so i made my own. i used 2 pieces of 4x4x1/4" steel angle. i cut it about 2" wide so i could off set the holes and had to cut off some of both sides and drilled some 1/2" holes. this first one was practice so i could get good measurements for the final product.
this is the factory bolt location. the existing bolt was too short for the 1/4" steel, luckily i had a much longer spare layin around, but to finish i'll find the right size
heres with the light mounted
i didnt get to finish the brackets, hopefully tomm. i am also going to apply truck bed liner to the brackets and the beam clamps. when i finish i will draw up a plan w/ measurements and post it, but i dont know if they will work on anything other than 98 sports like mine
