For slider, round or rectangle? | Ford Explorer Forums
Which is better as a slider?
  • Rectangular slider
    Votes: 12 66.7%
  • Round slider
    Votes: 6 33.3%
  • Total voters
    18
swak6287
Rockwall tx
99 XLT
ok, building my slider. what would be better, long rectagular tube or round? if round, it would be easier cause we just buy a 2 inch thick steel pipe whereas rectangular we will have to find a place that actually has it.
thanks.
comment?
Why would it be easier to get round tubing as opposed to rectangular?
cause thick metal pipe canbe found at any hardware store.
Hardware store steel, or cast iron, pipe is made to plumb low pressure gas.......not as structural steel tubing. It would be a major mistake to build sliders out of it. You want to use steel tubing, not pipe.
As far as using round or rectangular, I like the round.
steel tubing... i see. learn something new everyday.
Round has an advantage if you're using a high lift on it and your vehicle is not level...
Buy some from CoryL..... They are round and totally kick a$$.
one of the 2 has to be stronger....what ever is stronger i would go with
the rectangluar is going to be stronger but if you put 3 braces on each one for each side there should be no problem with either
the strength of each depends mostly on the dimensions of the cross section.
In bending, (which is what happens when you land on a rock) a rectangle tube [] would differ in strengh depending which way you turn it, like a 2X4. A round tube O does not matter. Then you have to consider overall size and wall thickness.
Just my guess, round tube is probably cheaper in would give a better look.
AHHHHH! Visions of t=(VQ)/(It) and sigma = My/I just flashed through my head...
I voted for neither because I like a combination of both. Rectangular tubing under the rocker pannel and then round tube extending out to protect the sides of the body and serve as a jacking point. I am going to be redoing my sliders in the future using this style and I am also using this style on my trail jeep.
well here is a pic of my round sliders
You can do all that with round tubing also.............
Wow...those are soo...Silver still! I have never seen that pic before....You holding out on us Robb? I have only seen the rusty pic:(
Robb, why don't those sliders extend a little farther front and rear? Seems like you could still catch a rock on the body behind the front wheel
That pic is just shot at a weird angle. There really isn't room between the slider and the tires. It does look like there is a gap in the front, but there really isn't.
Crankcase, are you kidding? I am holding back everything from the forums! You know this!:D
