Fischer
- November 25, 2001
- Durango, Colorado
- 95 Explorer XLT 4x4
I got this from the Motorcraft Website.
Part Number Description:
JK6-876-A [Serpentine Belt] w/AC
BRPK-5624 [Front Hardware Pad Attachment Kit]
BRPK-5627 [Rear Hardware Pad Attachment Kit]
XT-2-QDX [Transmission Fluid] MERCON; 4R55E Trans.
CVH-31RM [Left Shaft] Front
CVH-32RM [Right Shaft] Front
CX-1828 [Idle Air Control Valve]
CX-1845 [Idle Air Control Valve]
CX-1846 [Idle Air Control Valve]
CM-4750 [Fuel Pressure Regulator]
CM-4713 [Fuel Pressure Regulator]
CM-4685 [Fuel Pressure Regulator]
P154 [In Tank Electric Fuel Pumps] (2 Door); (4 Door); Pump Assembly & Module.
P264M [In Tank Electric Fuel Pumps] 2 Door & 4 Door
E2059M [FUEL PUMP-ELECTRIC] (USA and Canada Built)
EV-225 [PCV Valve]
DY-619 [Oxygen Sensor]
DY-733 [Heated Oxygen Sensor]
DY-734 [Heated Oxygen Sensor]
DY-729 [Heated Oxygen Sensor]
DY-831 [Heated Oxygen Sensor]
SW-5919 [Speed Control Actuator Switch] Dual Switch Assembly w/Ground Wire On LH Side
SW-5913 [Speed Control Actuator Switch] Dual Switch Assembly w/Ground Wire On RH Side
SW-5945 [Speed Control Deactivator Switch]
FG-872 [Fuel Filter]
FT-103 [FILTER KIT] 4WD
FT-102 [Transmission Filter]
FT-103 [Transmission Filter]
WR-4062 [Spark Plug Wire Set]
XT-2-QDX [Transmission Fluid] MERCON; 4R44E Trans.
E8TZ-19590-A [High-Temperature 4X4 Front Axle and Wheel Bearing Grease]
XL3Z-19G208-AA [Mini-Vent Window Lube]
E6TZ-19581-A [Speedometer Cable Grease]
XG-3 [Silicone Brake Caliper Grease and Dielectric Compound]
.054 IN. [Spark Plug Gap] Plug # {AWSF42PP}
AGSF42EEM [Alternative Platinum Plug] Aerostar, Explorer, Ranger
646EEM [Alternative Platinum Stock Number] Aerostar, Explorer, Ranger; Includes All Models
AWSF42PP [Standard Service Plug] Aerostar, Explorer,
Ranger; Service Replacement Double Platinum Spark Plug for O.E.Installed P & PG or E & EG Suffixed Plugs
6W9 [Standard Stock Number] Aerostar, Explorer, Ranger; Includes All Models
XT-1-QF [Ford Type F ATF & Power Steering Fluid] (1 Quart)
F7AZ-3F823-BA [Premium Power Steering Fluid]
F7AZ-3F823-AA [Power Steering Fluid]
TRM-1264 [Assembly - Automatic Transmission] Automatic; 4x4; F68Z-7V000-EBRM; 95GT-7000-GAA; 4R55E
Automatic; 4x4; F68Z-7V000-EBRM; 96GT-7000-EBA; 4R55E
MTK-27900C [Overhaul Gasket and Seal Kit] 4R44E/4R55E Trans.
MTKV-LS2700B [Master Overhaul Kit Less Steel] 4R44E/4R55E Trans.
MTKV-K2700A [Master Overhaul Kit] 4R44E/4R55E Trans.
XL-3 [Motorcraft Additive Friction Modifier]
C8AZ-19B546-A [Additive Friction Modifier]
11501 [Locking Fuel Cap] Pre-Vent
FC-926 [Fuel Filler Caps Regular] All
EC-743 [Oil Filler Caps Std. Painted]
EC-743 [Oil Filler Cap] Standard
RS-76 [Radiator Cap] REGULAR TYPE
N/A [Thermostat Housing] Available Only Through A Ford or Lincoln/Mercury Dealer
RT-1086 [Thermostat] 190 Ex. Hi Temp; OHV; Opens at 197<.
PW-349 [Water Pump]
VC-4-B [Premium Engine Coolant ] (Green)
VC-7-C [Motorcraft Premium Engine Coolant ] 55-Gallon Drum
VC-7-A [Motorcraft Premium Gold Engine Coolant] 1-Gallon
VC-4A1 [Premium Engine Coolant ] (Green)
VC-4-A [Premium Engine Coolant ] (Green)
VC-7-B [Motorcraft Premium Gold Engine Coolant] With Bittering Agent (Oregon); 1-Gallon
VC-3 [Specialty Orange Coolant] (with Bittering Agent - Oregon)
VC-5 [Premium Engine Coolant] (with Bittering Agent - Green)
VC-2 [Specialty Orange Engine Coolant]
EV-225 [PCV Valve]
PW-349 [Water Pump]
