Explorer XLT 4x4
- October 24, 2006
- Finland
- Explorer 96 XLT Black
Hellou!
I am from Finland and I have `96 Ford Explorer XLT 4x4. When I start the engine for the first time of the day I hear a little noise.. it sounds like a turbo When I start to drive its get louder, and when the transmission gets to a shift point the noise almost stops but when the transmission changes to the next gear the transmission get same noise again until the next shift getting "lock". Once I have driven about 2 to 3 miles the noise stops, I think that then the transmission fluid isn't cold anymore? I doesn`t have full synthetic atf, just the "ATF 320" I don;t know what kind of fluid there was in it before the change.
I changed the fluid, since it wasn't red anymore, but more of a brown color, so I think that the same fluid must have been in there for a long time.... However when I change thte fluid only half or so comes out, so what's there after a change is half old and half new... so how i get all old fluid/oils exit of transmission?
Does anyone have any idea what part started making noise like a turbo when the transmission/oils are cold? turbine clutch?? and if you know what part is it, how big of a job is it is it change that part and how much does it cost?
Explorer is fantastic car but only the transmission is little started to work strange
what i should to do???
thanks for answer! you can also send answer fordisti@hotmail.com
