Ford Jet Performance Programmer!! | Ford Explorer Forums - Serious Explorations
Status
Not open for further replies.
I recently got this for my Explorer, but my transmission went out, so I have no choice but to sell this to raise money for a rebuild. This programmer is amazing. You can do the Jet E.Z Tune, or you can custom-tune your vehicle! You can choose Regular, Mid-Grade, or Premium Gas Tune, Adjust Shift Points, Modify Shift Firmness, Raise RPM Limiter, Remove Speed Limiter, and many more features! This unit also doubles as a Check Engine Light Code Scanner and you can clear codes (Great for needing to pass inspection!!) Here's the item description online:
"The JET Performance Programmer lets you take control and program your own vehicle computer to match your driving style. JET's exclusive Tri-Power tuning allows you to program for performance using lower cost regular octane fuel, or for optimal performance gains you can program for midgrade or premium fuels. All three tuning modes are designed to operate the engine at peak efficiency based on the octane level being used to improve horsepower and mileage. The advanced technology and design of the JET Programmer gives you the ability to modify air and fuel ratios, ignition timing, shift points, shift firmness, speed limiter and rev limiter settings. The programmer will also correct your speedometer and turn off the ABS system trouble light if you change tire size or gear ratios. Also includes a built in scan tool to read and clear diagnostic trouble codes when your check engine light comes on saving you a costly trip to the dealer. The programmer simply plugs into the vehicle's diagnostic port under the dash and then the easy to use installation software allows you to make your changes by answering simple yes or no questions. Take the next step in performance tuning with the JET Performance Programmer!"
**This unit works on HUNDREDS of Ford Vehicles, so if you're interested, tell me what your vehicle is and I'll tell you if it will work! I'm asking $200
((Stock Photo Shown - Unit is the exact same - Just blue!))
I'm asking $200. You won't find one cheaper
Do you have the model number?
So i guess it wont work on 96 xlt 4.0 ohv 4x4
That I'm not sure of. It only says 1996-2000 Explorer 5.0...but it also says 1996-2004 Ranger 4.0L (Same engine as Explorer V6?)
Price Down
Price is now $180. I really need this to sell :( I'm almost at enough to replace my transmission.
So this will work on a 96 5.0 ?
Status
