FORD'S "updated" intake manifold gasket VS Fel-PRO update...? | Ford Explorer - Ford Ranger Forums - Serious Explorations
35Remmy
Binghamton NY, Hazleton PA, Northern NJ
'88,'99 Ranger, '00 EX
Just purchased the Fel-Pro intake manifold gasket set which includes the upper and lower intake gaskets, valve cover gaskets, etc...90$ at Advance Auto.
The new lower intake gaskets are 2 PIECE metal with rubber around the ports...the FORD "updated" lower intake gasket is metal and ONE PIECE.
The Fel-Pro set has an insert which says that, "the one-piece design with molded end seals has been eliminated because we found that in many cases the seals hold up the manifold and create leaks. RTV is provided for sealing the end rails".
Thought this was interesting...;)
Does anyone know the torque specs (IN. LB) for the lower and upper intake manifolds? I'd appreciate it!!!
wood1
North of Edmonton
'93 XLT, Cayman Green RIP
NAPA says: Lower Intake
4 steps, 1- 35-71 INCH Lbs (4-8 N.m)
2- 6-11 Ft. Lbs (8-15 N.m)
3- 11-15 Ft. Lbs (15-21 N.m)
4- 15-18 Ft. Lbs (21-25 N.m)
Upper 15-18 Ft. Lbs (20-25 N.m)
Regards.
35Remmy
THANKS Wood!!! I really appreciate your help. Cheers
Lefy
Westchester, NY
98 Sport 4x4 4.0 SOHC
does that really fix the problem
I just picked up the 15 dollar felt pro upper and lower gaskets. are those others that much better
