Basically what you need to do is take the voltage from your battery and invert it to output low amperage high voltage (400-450 D.C. Volts ), and at 3 or 4 points around the vehicle you send this voltage into the frame and chassis through capacitive couplers, essentially turning your entire vehicle into a giant coupler with the vehicle acting as the negative plate and the capacitive coupling points as the positive plates. The charges are localized but continually hold an overpotential on the metal surfaces of your vehicle thanks to the insulating layers of paint on the body. So while normally during corrosion OH- are being generated as a byproduct of the iron giving up 2 electrons, the constant field charge of the coupling effect your vehicle now has stops the chemical reaction from shifting electrons to the right. This is especially important in preventing chips, and scratches from starting the initiation step in the reaction of Fe(solid) = Fe - 2e- which in turn would normally generate oxidizing hydroxyl groups when mixed with moisture or good old H2O.
Should also be noted that because this is DC voltage with almost no Amperage it has absolutely no effect on your vehicles electrical systems or computer. I mean your could hold on to a million volts with your tongue as long as there was no amperage.
Hope that helps explain it a little better. Don't have pics or drawings but I'll see if I can borrow a digital camera and show everyone my setup and lack of rust looks like.
I'd even be willing to put together some kits if enough people are interested. I could sell them for about $50 with a profit to me of around $10 per unit.
