ERIC
- July 2, 1999
- Wilmington, NC
- '96 XLT
Originally posted by Ray Lobato
Hey Eric,
Did you replace the whole assembly or just the sensor on the front? Also what was the reason for replacing the rear sensor?
Ray, I replaced the whole assemby because there turned out to be a broken seal on the inside of the hub...I frankly handed that over to the dealer as it was more of a job than i could handle. In the process, both the exciter ring and sensor were replaced.
The rear sensor turned out to be bad one, so I replaced that one at the same time.
Basically, I was wrong about the front sensor having been replaced incorrectly, so I gotta eat some humble pie on that issue. Well, it isn't the first time...probably won't be the last! ;-)
