AlsExplord
- September 23, 2006
- Long Island, NY
- 2001 Lincoln Navigator
So I had a clankity clank noise when pulling off and coming to a stop and serious vibration between 45 - 55 mph. I found out that it was a bad universal joint on my front driveshaft. Found a how-to on removing the driveshaft and replacing the u-joints which seemed to be straight forward with only one side of the drive shaft being a pain in the @$$ to remove the bolts. I got all of the bolts removed on BOTH sides of the drive shaft but cannot pull the shaft out. The side of the shaft closer to the front axle is off and hanging but the other end of it doesnt seem to want to budge. WHAT AM I DOING WRONG!!! UGGGHH!!!
I am sooo pissed right now because I thought I had the hard part licked, even taking pics so I can post a how to for doing it on my vehicle(2001 Linc Navi A4WD).
I'm stuck and its my only means of transportation. HELP!!!!!
