Front end Humming noise | Page 2 | Ford Explorer Forums
If you had a stethoscope on it, then you found the problem. Assuming nothing is rubbing, then its the wheel bearings. Inside the hub are inner and outer wheel bearings, and also an axle shaft bearing. If your axle shaft isn't turning, then its the wheel bearings.
