front end rotational clunk | Ford Explorer Forums
spotted dogs
merritt, bc, canada
98 ltd 4.0 sohc
I've been up early researching and to no avail....last night in the next town away, heading home with the family and a truck load (birthday gifts and costco!) I hit the highway and a short time after getting to speed I started to get a prounced thumping....out of the front end..I thought I had a flat..it wasn't...I managed to limp to a weigh scale and get a tow 80km home... It is definately a rotation clunk, even coasting in neutral. No funny engine noises, tranny shifts into park, neutral OK..and nothing catastrophic is evident underneath (no visible breaks, leaking fluid). It is not a bearing..wrong sound...could it be drive shaft/front diff?..U joints..the back seemed intact...?
thanks,
P
I vote front drive shaft
Look at the small rubber boot on transfer case end--inside the cv hinge- if it is torn, it dried out--not uncommon. You may need to drop it out to see well, as the tear may be hard to see with it in the truck.
