rickybobby
- June 26, 2010
- Battle Creek, mi
- '97 XLT
Hah ok.
Number one , is the transmission which was absolute junk. Two , the engine was awful. 4 liters and only 150 hp. That's sad. Jeremy Clarkson said it best when he said "How do they get such a small amount of power from such a huge engine?"
And before you say "it's not about power , it's about torque" , save it. This isn't a tractor. It's suppose to be a car.
Three , Unreliability. Your personal stories mean nothing. They don't refect what the majority of explorers are. Go on ebay , go on yahoo cars , go on criags list. Try to find a first gen with over 250k on it. You might find one or two?
Now try to find a toyota or honda from the same year with 250k. There's tons of them. Hundreds infact. That's because given the same age , and lack of matinence , they lasted longer then the explorer. Because they were designed and built better.
And by the way , I've owned 3 first gens. Count em, 1 , 2 , 3. I have an emotional attachment to the make and model. But all three were terrible and cost far more in repairs then any of the 14 cars I've owned.
If I'm going to buy a vehicle based on it's looks alone and ignoring it's awful track record , then I'm going to get the one that sucks the least and could potentially look the same. And thats a second generation explorer , not a first.
The 5r55e is just as bad as the a4ld, and other that the shape of the cumbustion chambers in the head nothing changed in the ohv until mid 97. in mid 97 they changed the crankshaft to be able to use the same flywheel as the SOHC. in 99 they changed the shape of the exhaust port. so as far as reliability nothing really got better in the 2nd gens except the v8. And i dare you to try to find a 5.0 explorer in good mechanical condition for $1500. In my area you are paying 2k with rusted out rocker panels and dog-legs. if you find one with a clean body and lower mileage they start at 4k and go up from there. As far as the HP numbers you posted, i would like to see some kind of proof, as the lowest spec ive seen was a little over 160, and that was a 1st gen manual with the lower performance cam. my 97 is rated to 172hp, and im fairly certain it is a bit under rated due to the fact that it can easily keep up with my GMC Envoy that is rated to 291hp. and before you call it a car, keep in mind that it is a sport utility vehicle, NOT a car. part of utility is torque. why would a 4000lb cinder block on wheels need to make gobs of HP when torque is needed to get it moving?
