Explorerman2
- November 17, 2006
- Brighton Sussex
- 1999 Explorer
Hi
My front screenwash has stopped working. The rear works fine. So I guess it's the fuse, switch or motor.
Curiously the driver's handbook doesn't show the fuse (but it does for the rear washer). I've checked all the fuses and they appear fine and the tubing is dry so I'll rule out jet blockage. It seems easier to check the motor before the press switch . Presumably the hidden away washer bottle has two motors one for the front and one for the back. I guess I have to remove the washer bottle (combined with rad mixture). Is it just two bolts and lift (wiggle) out?
Is it best to test the motor with a direct 12v and earth to the motor leads (I assume it's only two leads?).
Any help/thoughts greatly appreciated
Many thanks
Many thanks
