Front Shock install problem | Ford Explorer Forums
jbain2
Glen Cove, NY
92' XLT
I was replacing the front shocks on my '92 Exp and sheared off the lower mounting bolt. The retaining nut had rusted out the bolt. Is there a way to replace just the shock mount bolt or do I need to replace the entire radius arm? Thanks.
I think I have heard of this happening to other members. Have you tried a search?
Can you drill a new hole in teh radius arms and use a bolt and washer to replace the now broken stud?
The shock mount is welded to the radius arm. I would have to put the hole in a different location. Thanks for the reply.
This is normal on 1st gen X's- NAPA makes a replacement mounting stud- gotta cut the broken stud off ( I used a cutting wheel on my 4 1/2 " grinder), grind it down flat ( you can leave the raised shoulder, just make sure the face of it is flat or slightly concave), then drill the radius arm for the new stud. I used a punch to "dimple" the center of the new hole ( this keeps the drill from "walking"), and stepped the operation with 3 progressively larger bits, the last one being the required 1/2" size. Works good, lasts long time.
Thanks for the reply. I have a Napa up the street, I will give them a try.
