Hi,
I just want to know if you have to replace the whole front wheel hub assembly or is it possible to replace the bearing only?
Thanks,
Orlando
Depends if yours if 4x4 or 2wd. If it is 4wd then, yes, you do have to change the whole hub. Its not very hard at all. And if it is 2wd then all you have to do is replace the bearing.
Yeah its not hard but I recommened a breaker bar to remove the bolts that hold the hub in place, on my truck they were very tight and I couldn't remove the bolts with just a rachet, even on hubs I had replaced myself in the past.
