Tremblor
- June 29, 2009
- Kamloops BC
- 92 XL
So i took my truck to a 4.0L specialist, and he said the most common cause for fuel in the oil in one of these is one injector will not seal properly after the truck is shut off, therefor leaking fuel into the oil over time. The thing i wanted to know was, is there any way to determine which injector it is? any signs i can look for to see which one is leaking? Any suggestions would be greatly appreciated.
Also, i did a compression test and cylinder 6 was down 15-18 PSI then the rest, could that mean fuel is washing out my rings in that cylinder? Maybe replace the number 6 injector? any ideas...
