justin_b31
- April 14, 2008
- Salt Lake, Ut
- '93 XLT & '02 XLT
1993 Explorer (pushrod?) is failing emissions. Shop figures out that cylinder 6 is not contributing.
Their testing:
spark test
compression @110
pull ignition wire from each cylinder, one at a time, to determine power loss
swapped ignition wire to 6 (don't know which one)
Based on the diagnostics, cylinder 6 has fuel delivery problem. Asked them about regulator and their response was that, because 5 was good, 6 should be fine too ...
Now I have the throttle body and fuel rail out.
At the FPR I applied 15 (psi?) vacuum with a mighty-vac tool. Vacuum held for 5 or so minutes. Can I assume this is the extent of the testing? Replacement suggestions?
Injector 6 came out next and I rigged an injector tester. Here is a video of the injector.
Is this injector reusable? It appears to be the same spray pattern as another injector. Or should I just replace it just in case?
And what of the other injectors? Any advice about replacing the whole lot if I replace the one?
Thanks!
Their testing:
spark test
compression @110
Thanks!
