Fuel injectors | Ford Explorer Forums
Fuel injectors
hfskipper
Leesburg, FL
96 Limited
What is the pound rating on stock injectors in a 1996 5.0. Are they 24#?
Thanks for the information on previous thread "1996 Explorer will not start after storage" . I have 40# rail pressure, new filter, new pump and clean tank.
think now it may be that the injectors are plugged. Tank was a mess.
Thanks again.
19 lb/hr EV1/EV1 Injectors
Whoa, back up a bit
Like you I cannot believe they would all be clogged--
The camshaft position sensor circuit triggers the pcm injector firing order and duration. You might check that circuit.
Did you change the oil and filter?-if not, it may help.
what is in a 96 4.0 for injectors?
That is what I thought, they could not all be clogged. I have a pulse at the injectors and when I try to start, it acts like 1 or 2 cylinders try to fire. A friend of mine who was trained by Ford said before I pull the injectors to try hooking it up to his power flush machine. Said it might get it running well enough to see if that is what it needs. Your thoughts are appreciated.
