Explorer 4 sport
- July 29, 2016
- Houston, Tx
- 2003 Explorer Sport Trac
Alright experts, I'm in deep need for some help. I decided to buy a fuel pressure tester this weekend and run a test on the system. Is it normal for the system to complete bleed off pressure in 10 minutes? When I turn the key pressure jumps up to about 60 psi with a small fall off in pressure until I start. When the engine is running I get 65-70 psi which per the ford manual is the correct pressure for operation. When I turn the key off pressure drops to 55-60 psi and slowly continues to decreases until reaches 0 ten minutes later. Any insight on what the system should do would be great! Thanks
