Stick4503
- December 12, 2011
- Winder, Georgia
- 1996 & 2004Explorer 4x4
1996 Explorer with 4.0 ohv. Have had hot start issues and now occasional cold start.
Fuel pressure is 29 at rail with key cycle engine off, 29 engine running, 38-40 with vacuum line to FPR removed. Engine is a little rough all the time but I have no power loss with acceleration.
Starting problem is when warm, car cranks over and fires but runner for just a few seconds, skips and sputters like it is only running on a few cylinders then dies. I have changed both temp sensors, cleaned MAF, changed fuel filter, swapped fuel relays, changed crank sensor, tested coil.
Haynes repair says psi 30-45. I have 29 psi key on and running. Can here pump running and can here fuel being delivered back to the tank.
Any ideas? ASAP please.
