koda2000
- September 2, 2011
- x
This morning I finished installing the new fuel pump (with new strainer and fuel filter) in my '97 Sport. The one I removed was the original '97 OE fuel pump with 260,000+ miles on it, so it was overdue for changing.
I tested the new pump before completely reattaching the fuel tank and heard it run, so all good there. Finished reinstalling the fuel tank, refilled the tank 1/2 way, primed the pump and still - no start...
I knew this was a possibility, as the old pump worked one day, no start the next 30 degree morning, then after me fiddling with fuses, relays and electrical connections (and the temp reaching the mid 50's) it suddenly decided to start and continued to start normally, several times a day for the next 6 days. It even started right before I dropped the tank to change the fuel pump.
Today, after numerous attempts to start the engine (hearing the f/p run each time) I decided to remove the cam position sensor and test it. I don't know if my test was valid, but I set my VOM on continuity, attached the leads to the 2 terminals and ran a magnet over the bottom and got a continuity chirp, so I'm thinking it's working.
Next I pulled a plug wire, installed an old spark plug in the wire and grounded it to the battery with my jumper cables, turned the ignition key to ON and jumped the fender-mounted starter solenoid to spin the engine. Saw no spark.
So, I apparently have an intermittent electrical problem. I swapped the PCM relay and pulled the PCM plug to see if I saw any corrosion (didn't) wiggled the coil connections and retested. Still no hint of a spark.
Lastly, I decided to check the connection on the crank position sensor. It had started raining and without having the front end up on ramps I could barely see or touch the plug, but I did push on it with a finger. Then I jumped the starter solenoid with the key ON one last time - saw spark and then the engine started running on the 5 connected cylinders. I then reattached the spark plug wire. Started the engine again and drove the truck up on ramps. I plan to do further examination of the crank position sender/plug tomorrow (when the rain is supposed to stop).
BTW: When I got the engine to start last Monday, I never went near the crank position sensor.
So what is your best guess as to what this apparent intermittent spark related electrical problem is?
