Fuel supply problem after engine swap | Ford Explorer Forums - Serious Explorations
93explorer666
BARRIE, ONTARIO, CANADA
1996 Mazda B-? now
Hey everyone
I just did a 4.0l sohc 99 engine swap into a 1996 ranger I removed the antitheft from behind the air bag and use all the wiring out of the explorer except the fuel because it is a returnless line system so I caped off the return on my plastic tank and wired and change the pump to the 99
I am having issuses with starting it
I only get 6.79 volt on the middle terminal at relay and that same voltage at the pump
Could the computer be holding me back
Please if some one can help
Only thing keeping me from completion on my build
Thank you
are you using the 99 ecu?
Yes I am and I also have a SCT tuner from James henson and we are reprograming the ecu
