Serious question, and thought I would try again...
Basically 2015 Ford Explorer Sport VS Commercial Garage Door = Broken Antenna.
Was able to drill out the bolt piece from the pigtail stuck in the base, but it appears that the base now has a small gap in the front where the roof meets the antenna base.
My question is: Is there another gasket inside the antenna base where the base bolts to the roof, OR is water free to leak inside my car?
I am guessing the heavy pressure on the antenna (that caused the antenna to snap) caused the roof metal to warp a bit. That I don't care about, but a leaky roof would be no good.
I cannot find ANYWHERE any sort of pic on how the antenna mounts to the car. I can find lots of pictures of the base top, but not from the underside.
I could order a shark fin and hopefully seal it, but what about something like expandable foam? Might that work too.
I really don't want to spend hundreds or thousands for bodywork and/or antenna repair if I don't need to.
Thanks!
Thanks!
