airplane99tr
- September 2, 2014
- Illinois
I am new to this group. I am rebuilding a 1995 Explorer.
The gauges on the right side of the panel do not work.
The Tachometer seems to be sticky or has a bad ground. If you hit a bump or hit the top of the glare shield sometimes the tach will turn on for a while then off again. The Oil Temp and Fuel Gauge are also inop. Is there a bad ground wire on the left side? The right side gauges and speedometer work fine. This vehicle was not driven for the last three years. I know how gauges work and it seems there must be a common problem to all three although I would think there would be a common buss for both the right and left side.
